Changing the size of the iControl bar   [RESOLU] - View the solution
sifranc
by sifranc » Mon Dec 22, 2014 1:27 am
i want specific sizes for the iControl bar (700 pixels wide with 7 icons and 300 pixels with 8 icons).
I can't figure how to do it, even in the skin.xml file.
Could someone please help me ?
Re: Changing the size of the iControl bar  [RESOLU]
by Destiny » Mon Dec 22, 2014 2:31 am
Hi.. If you need to change the span of the buttons you can do that from the Skins xml file..
Look for this code, just part of it.. You need to divide the number of menu buttons to get your px sizes.. Edit all the 45 numbers to higher numbers.. Some code strings with have two 45, edit both of them...
<action name="theme11buildMenu">
set(theme11button_pos, 0);
set(theme11backgroundwidthwhenclosed, 40);
set(layer[theme11btn_hidecontrols].x, get(theme11button_pos));
set(layer[theme11btn_showcontrols].x, get(theme11button_pos));
inc(theme11button_pos, 45);
if (device.desktop,
set(layer[theme11btn_display_help].x, get(theme11button_pos));
set(layer[theme11btn_close_help].x , get(theme11button_pos));
if (device.fullscreensupport,
set(layer[theme11btn_openfs].x , get(theme11button_pos));
set(layer[theme11btn_closefs].x, get(theme11button_pos));
set(layer[theme11btn_autorotate_on].x , get(theme11button_pos));
set(layer[theme11btn_autorotate_off].x, get(theme11button_pos));
sifranc
by sifranc » Mon Dec 22, 2014 9:26 am
thanks Destiny for answering so quickly !
I'll try that as soon as I can!
Have a nice day !
