alter combo box size for mobile independently
bob1010
Liked in: 3 posts
by bob1010 » Thu Jul 19, 2018 1:09 pm
I hope you can help on this one. The new combo box now appears smaller on the iphone & I don't wish to tick the box to increase the scale on mobiles in the advanced section as that make the thumbnails too large, could the panorama combo box size on mobile have it's own parameters within the style section when you click on the combo box plugin at all? I want it to appear the size it used to in the following tour without effecting the size of the thumbnails.
https://www.irisimage.com/360-degree-ga ... build.html
The new version appears small:
https://www.irisimage.com/360-degree-ga ... -with-ext/
bob1010
Liked in: 3 posts
Re: alter combo box size for mobile independently
by bob1010 » Thu Jul 19, 2018 8:05 pm
Would there be any way to incorporate the previous krpano combo box in the next update or copy the combo box plugin from an older version into 2.5.11 as a style option. It worked perfectly for my requirements and the text size was spot on, the drop down paddle used to increase in size and it made it really easy to navigate on iphones without having to enlarge all plugin sizes which made everything too large for my requirements. The new combo box is perfect on most platforms, I'd just like the flexibility to either revert back to the old combo box or have the ability to alter its size just on mobile phones, ipad's and tablets are fine it's just on the really small devices I have an issue:
Here are the comparisons of both combo boxes:
older version of combo box is the perfect size on iphone:
newer version appears too small on iphone
