Scrollarea.js decoding error after update to v2.5.11
Photosbykev
Likes: 9 posts
Liked in: 4 posts
by Photosbykev » Sat Apr 14, 2018 10:59 pm
Everything was loading and displaying correctly until I updated Panotour today and now the Combo dropdown box fails to load and the error above appears in the debugging. I've removed the combobox from the project and rebuilt it without and the project is ok. If I re-add the combobox this error comes up during the initial load.
Is this a known fault? or a new one from the software update?
regards
Kev Lewis
http://www.photosbykev.com
mterajewicz
Re: Scrollarea.js decoding error after update to v2.5.11
by mterajewicz » Thu Apr 19, 2018 8:28 am
Photosbykev
Likes: 9 posts
Liked in: 4 posts
by Photosbykev » Thu Apr 19, 2018 8:42 am
mterajewicz wrote:Same problem here:
http://www.openlens.pl/klub-stara-przep ... ie-dziala/
What's going on?
I've had zero response from Kolor so I guess they don't monitor their own forum very much :(
Kev
by benji33 » Thu Apr 19, 2018 2:21 pm
Sorry for the delay, it's a holiday time in France ;)
Do you have a link Photosbykev?
The issue is present online or on the localhost Panotour server (Green icon) ?
mterajewicz I have many issues on your tour, cf. attachment. Is it the same when played from the Panotour localhost?
by benji33 » Thu Apr 19, 2018 2:25 pm
Is it a Panotour -or- Panotour Pro tour please ?
With a simple thumbnails bar plugin ?
mterajewicz
by mterajewicz » Thu Apr 19, 2018 4:07 pm
benji33 wrote:Sorry for the delay, it's a holiday time in France ;)
Yes, at localhost it's the same.
I am not using the pro version, just regular.
Photosbykev
Likes: 9 posts
Liked in: 4 posts
by Photosbykev » Thu Apr 19, 2018 8:06 pm
benji33 wrote:Is it a Panotour -or- Panotour Pro tour please ?
Panotour Benji33 using a simple Menu > Panorama Combobox dropdown list. The error occurs if I include the Combobox in the build and doesn't occur if I remove it from the build.
regards
Kev Lewis
by benji33 » Fri Apr 20, 2018 11:42 am
Yes seems to be an issue with the encryted data of the plugin linked to the encryted tour JavaScript file.
I report that as Urgent to solve into a next release.
If a solution is found I'll post here the workaround.
Photosbykev likes this post.
Photosbykev
Likes: 9 posts
Liked in: 4 posts
by Photosbykev » Fri Apr 20, 2018 11:58 am
benji33 wrote:Yes seems to be an issue with the encryted data of the plugin linked to the encryted tour JavaScript file.
Thank you Benjamin
by benji33 » Wed Apr 25, 2018 2:26 pm
The issue is resolve on our side but you have to wait the next release for that due to the Panotour Standard encoding. I've no ETA date for it.
You can use the previous Panotour Std version if needed : 2.5.10
Photosbykev
Likes: 9 posts
Liked in: 4 posts
by Photosbykev » Wed Apr 25, 2018 4:37 pm
benji33 wrote:The issue is resolve on our side but you have to wait the next release for that due to the Panotour Standard encoding. I've no ETA date for it.
Thank you Benjamin, I'll stay with the current version for now, rather than end up with other oddities.
regards
Kev
