Is there any way to go 'Back' in a PanotourPro tour?
I see there are plugins to go to the 'next' or 'previous' item/group in the tour order but is there a way to go to the the most recent item before the current one?
Basically like hitting the backspace in a regular web browser.
Still looking into how this could be coded as a plugin.
1. Maintain a previousSceneId to go back to as an action - This could be a FIFO queue to keep a history of scenes
2. Generate a sort of 'Scenes that link to this scene' list and go back to one of these - Works well for my use case since I have a main tour loop that has many branches that I would want to return to the main loop - Would probably have to be created at build time to make a sort of hash map (M + N time) to avoid looping over every scene on scene load
option 1 seems the most universally applicable and useful. I'm still new at making plugins with Krpano and I'm not sure what kind of drawbacks there are to using the javascript methods.
i have done 2 variations of this, both without Javascript:
The first approach enables to go back to the last seen pano, it does not maintain a list of all panos seen so far. This can be done by modifying the "mainloadscene"-action on startup to save the current scene before doing the switch, then you can call the mainloadscene-action from a button like this: "mainloadscene( get(LASTPANO) )";
The other solution uses a modified version of the new Combobox, the "onnewpano"-event is used in this case to dynamically create the list of all panos seen so far.
Although these plugins are not available in my shop, i do offer them on request, feel free to contact me at any time for details.
