error message   [SOLVED] - View the solution
pmmvergeer
by pmmvergeer » Thu Feb 01, 2018 7:16 pm
I make a pano 360. In the map I see the html file. When I click on it I ecpect that it open in a browser. But the browser open but give everytime a error:
ERROR:
Local usage with file:// urls limmited due browser security restrictions!
Use a localhost server (like the krpano Testing Server) for local testing!
etc.
Sometime I can make a pano....but often I get this error. I installed already Java....but it won't work.
What do I wrong?
Thanks for your reaction.
Paul
Re: error message
by Destiny » Thu Feb 01, 2018 11:34 pm
Hi..
A VR Tour is Web Based and so needs a server to view it.. By pressing the Green Preview Last Tour in PTP you are previewing using the internal Web Viewer.. To view the Tour outside of PTP you can use the KRPANO Testing server.. Otherwise you need to upload your Tour to a Web Sever..
http://www.kolor.com/wiki-en/action/vie ... ictions.21
pmmvergeer likes this post.
