Floor plan spot shows wrong group after navigating
bobjones
Likes: 8 posts
Liked in: 8 posts
by bobjones » Tue Sep 26, 2017 1:58 am
I have a simple floor plan in this tour with a spot showing the start of each group area.
I have bouncing spot animation to show the viewer which area they are in.
http://chrisogrady.com/virtual-tours/map-test/virtual-tour.html
The client pointed out that sometimes after navigating the tour, the wrong area point shows on the floor plan.
Meaning after selecting area 5 and then navigating to area 7 the spot still bounces in area 5.
Also, sometimes the map pin does not bounce at all after navigating even in the same group.
This bug is holding back delivery of the tour at this point.
Is this an known issue or is there a fix?
Re: Floor plan spot shows wrong group after navigating
by Annis » Tue Sep 26, 2017 10:29 am
If you navigate to a group, move to a different panorama in that same group but this scene does not have a spot on the map, there will be no bouncing animation. The animation is only for the current panorama, not the group.
As for the wrong area point showing, I'll have to do some tests, did any specific scenes show this erroneous behaviour or was it random?
bobjones
Likes: 8 posts
Liked in: 8 posts
by bobjones » Tue Sep 26, 2017 10:40 am
This is the problem.
Load the tour, push the map button. It shows area 1.
Navigate to area 2 and go a few panos in so you are not at the entrance.
Press the map button and it still shows a bouncing pin at area 1.
There is animation of the pin when you move to other panos.
by Annis » Tue Sep 26, 2017 3:52 pm
I'm not experiencing your issue with the pin going to the wrong area.
What is your browser & version?
By the way, you might be interested in using the Hotspot Visited plugin by Michael Brüning, it should mark the pins that have been visited so viewing would be easier? http://www.kolor.com/wiki-en/action/vie ... ts_Visited
bobjones
Likes: 8 posts
Liked in: 8 posts
by bobjones » Wed Sep 27, 2017 2:18 am
I'm using chrome latest (I assume).
I created a video: https://youtu.be/4C4jFt-fWW8
First pano into area 2 still shows a bouncing pin for the first pano of that group.
I go back and it does not bounce.
bobjones
Likes: 8 posts
Liked in: 8 posts
by bobjones » Wed Oct 04, 2017 4:36 am
Hi, client is complaining about this.
I was waiting to deliver the tour until this is fixed and I was waiting to hear from you.
I haven't heard anything back.
Do you see it happening in this video? https://youtu.be/4C4jFt-fWW8
I really hate telling clients I have bugs in the software I use... they are frustrated I did not get back to them sooner with a fix or an explanation.
Now I'm just going to tell them it's a bug and we can't have a bouncing animation on the map at all.
