Gyroscope + Autorotate on Mobile
bobjones
Likes: 8 posts
Liked in: 8 posts
by bobjones » Sun Aug 27, 2017 8:36 am
On this tour using 2.5.8...
I was viewing the tour with the gyroscope and auto rotate started. I could not turn auto rotate off until I stopped the gyroscope.
http://chrisogrady.com/virtual-tours/se ... -tour.html
Loading the tour again it seems to be fixed.
Is there any reason auto rotate would start on mobile with the gyroscope enabled?
Re: Gyroscope + Autorotate on Mobile
by benji33 » Thu Aug 31, 2017 12:14 pm
Autorotate + Gyro is a kind of aberration ;)
Thanks for this report, I've added a issue for verifications.
bobjones
Likes: 8 posts
Liked in: 8 posts
by bobjones » Sat Sep 09, 2017 5:10 am
Autorotation is now randomly breaking on the desktop version of this tour as well.
Is this a known bug? I'm using several third party plugins as well.
I was not using any third party plugins the first time it happened on mobile.
Autorotate stops and I can't start it again on desktop randomly.
I need to find out where this is coming from, I can't deliver this tour to the client with rotation randomly breaking.
by benji33 » Mon Sep 11, 2017 9:13 am
Is it possible to send me the kpt file to try to reproduce the issue with same settings as you ?
Thanks,
bobjones
Likes: 8 posts
Liked in: 8 posts
by bobjones » Mon Sep 11, 2017 3:24 pm
PM Sent.
benji33 likes this post.
by benji33 » Wed Sep 20, 2017 1:21 pm
I've made a test on iPhone and Samsung S6 with your project, without the external plugins. And I've no real issue.
The autorotate status is set to paused when the gyroscope is activated and in resume when deactivated. Even if the gyro and autorotate are activated on start.
Do you have an other workflow to test your issue ?
