Enabled flash fallback - Wont work   [SOLVED] - View the solution
360panosi
Likes: 4 posts
Liked in: 7 posts
by 360panosi » Wed Aug 17, 2016 6:44 pm
Hello to everyone,
I have a question: I using Panotour Pro 2.5.3 (Mac version), generate the tour with enabled flash fallback and my virtual tours won't work when the html5 not work, so when the flash is enabled. I get this feedback from the useres who have older PC's with Windows Xp, Windows 7.
See the links that won't work:
http://360pano.si/panorama/2016/07/Retro/retro.html - WORK
http://360pano.si/panorama/2016/07/Retr ... tml5=never - NOT WORK
http://360pano.si/panorama/2016/07/Retr ... ash=prefer - NOW WORK
and this
http://360pano.si/panorama/2016/07/Retr ... /retro.swf - NOT WORK
So where is the problem?
Re: Enabled flash fallback - Wont work
by Annis » Thu Aug 18, 2016 9:49 am
Loading the .swf directly definitely won't work, no matter the PC.
What exactly happens when it "doesn't work"? Black screen, nothing loads, it freezes, it crashes, error messages? What -precisely- happens?
360panosi
Likes: 4 posts
Liked in: 7 posts
by 360panosi » Thu Aug 18, 2016 9:53 am
The tour must start with little planet effect with rotation, i see the little planet but it's stops and nothing happen.
by Annis » Thu Aug 18, 2016 10:01 am
Edit retro_skin.xml file and remove the wait(0) at line 313.
360panosi
Likes: 4 posts
Liked in: 7 posts
by 360panosi » Thu Aug 18, 2016 10:37 am
I remove the line 313 wait(0);
No changes, it's the same.
360panosi
Likes: 4 posts
Liked in: 7 posts
Re: Enabled flash fallback - Wont work  [SOLVED]
by 360panosi » Thu Aug 18, 2016 11:33 am
Ok I SOLVED by deleting in retro_core.xml the following line:
if (sceneisfull360,
wait(0); - i delete this line
fromlittleplanetintrotonormalview();
Annis likes this post.
