Combo box dropdown paddle oversized on iphone 5
bob1010
Liked in: 3 posts
by bob1010 » Mon May 16, 2016 3:37 pm
Hi Benjamin,
Just done a test in 2.5.3 with the combobox & have spotted a small issue with the drop down paddle size on my iphone. The paddle is the correct size on PC in all browsers I tested, including Windows 10 Edge browser (PC tested not mobile or tablet) but the drop down paddle appears oversized on my iphone 5s in Safari compared to the sizes of the combo box. I ticked the option not to resize the plug-ins for mobile devices, the thumbnails are the correct size & the actual combobox is correct, it's just when you click the box that the drop down itself is oversized.
Here is the test: http://www.irisimage.com/360-degree-gal ... build.html
Can that be fix for the next release, is the workaround to replace the following code as before?:
CODE: SELECT ALL
itemfontsize.normal="14"
itempadding.normal="8"
itemfontsize.mobile="11"
itempadding.mobile="5"
cbdesignscale.mobile="1"
replace with these lines :
CODE: SELECT ALL
itemfontsize="14" itempadding="8"
kind regards,
Rob
bob1010
Liked in: 3 posts
Re: Combo box dropdown paddle oversized on iphone 5
by bob1010 » Tue May 17, 2016 9:33 am
Hi Benjamin,
Here are a couple of screen grabs to illustrate the issue, the first shows the combo box at the correct size before it's clicked, the second shows the drop down paddle oversized on iphone 5
combo box correct size before clicking
combo box oversized drop down paddle
I've also done a test with the previous code work around will upload those also as it wasn't successful unfortunately.
bob1010
Liked in: 3 posts
by bob1010 » Tue May 17, 2016 9:41 am
Here are a couple of screen grabs to illustrate what happened when I used the following code to try to correct the oversize dropdown:
CODE deleted:
CODE replaced with:
here's the result on the iphone 5:
The combo box is very small:
combo box very small
And when clicked its appears like this:
view when clicked
Hope that helps, there is also an issue with the simple thumbnails which I'll upload separately
Regards,
Rob
bob1010
Liked in: 3 posts
by bob1010 » Fri May 20, 2016 8:55 pm
Hi, had a reply from Klaus on this one, will email the combobox.js through if it's any help?
Cheers,
Rob
thanks for the report and yes, there was a bug here:
The wrong font was used for the inner width calculation. The plugin was wrongly using the font of the combobox element itself and not the font for the inner items.
The reason why this was happening only on mobile was that Panotour was defining different fontsizes for desktop and mobile.
Attached a fixed combobox.js.
Best regards,
neilhenderson
by neilhenderson » Fri May 05, 2017 12:00 pm
this is interesting - would you know how to change fonts or colours on these dropdowns?? want to use lato and change background colour to a blue?
by Annis » Fri May 05, 2017 12:06 pm
neilhenderson wrote:this is interesting - would you know how to change fonts or colours on these dropdowns?? want
Please do not revive a year old topic, instead create your own topic linking this one if needed.
Edit: I replied on your topic.
