2.5.1 Menu Thumbnail Bug...
bobjones
Likes: 8 posts
Liked in: 8 posts
by bobjones » Mon Mar 07, 2016 4:33 am
I'm using small png 35 pixel icons as thumbnails in my menu in a rather large tour.
I updated to 2.5.1
The thumbnails worked properly upon the first build
When I created a new group and added an icon the entire menu would not display.
I created a new default menu and it showed up without the icons.
Deleting the new added png thumbnail and used the default it would show with the default pano thumbnail along with the pngs.
I went back to 2.5.0. Added the new png icon I was trying to use and it worked but all the others have been reverted to their default pano thumbnails.
Over an hour wasted with this one today... Looks like there is a bug in the thumbnail generation in 2.5.1.
Custom menu icons are working normally in 2.5.0
Re: 2.5.1 Menu Thumbnail Bug...
by benji33 » Mon Mar 14, 2016 2:01 pm
Custom thumbnails doesn't work in your case ?
Is it possible to send me a complete workflow from scratch (empty project) to try the same actions and see if I can fall into the same issue ?
bobjones
Likes: 8 posts
Liked in: 8 posts
by bobjones » Tue Mar 15, 2016 12:34 am
Don't have the time.
