Point spot do not load the custom view in VR-mode
Virtuel Rundtur
by Virtuel Rundtur » Wed Nov 11, 2015 9:33 am
Hi
I have made a couple of tours which are VR-mode enabled.
When I follow a point spot, it does not load the custom view of the new pano, even if have selected that in the action parameters of the hotspot. I have tried setting the orientation on all panos, but with no success.
The error only shows up in VR-Headset mode.
Im using PTP 2.5 Beta 4 on Mac
Best regards
Henrik
Cliquetsy
Likes: 106 posts
Liked in: 119 posts
Re: Point spot do not load the custom view in VR-mode
by Cliquetsy » Wed Nov 11, 2015 12:31 pm
VR mode uses a transition similar to keepview that I forgot the name of, so that the users aren't disorientated when viewing a tour, it overrides your custom view.
Virtuel Rundtur
by Virtuel Rundtur » Wed Nov 11, 2015 8:36 pm
But the panos do not show up in the right direction, even if I have set the north correct on all panos.
Anybody know how to fix this?
Cliquetsy
Likes: 106 posts
Liked in: 119 posts
by Cliquetsy » Wed Nov 11, 2015 11:21 pm
Then I'll assume it uses the pano original information (meaning, where the center of the equi shows and not information that you'll have added from PTP) just like for keepview. The image itself has to be 'straight'.
by benji33 » Wed Nov 18, 2015 10:38 am
I agree.
For the moment the default view is always used into VR mode as Cliquetsy said.
A way to be able to apply the custom view in this case is opened in our side.
ido360 likes this post.
