I must do something wrong
eric_5dmk2
Liked in: 5 posts
by eric_5dmk2 » Sun Apr 22, 2018 12:50 pm
I'm having a trouble with on of my pano;
it's been assembled with APG, added some sky (pano created with a drone) and looks okay for me.
When I import the file in PTP, this image is distorted (check out the screenshot).
I also have Pano2VR & don't have this issue.
If you know what I'm doing wrong, please let me know.
eric
Re: I must do something wrong
by Destiny » Sun Apr 22, 2018 10:35 pm
Hi.. Have you used the Straightening Tool.... Just click from one end to the other..
eric_5dmk2
Liked in: 5 posts
by eric_5dmk2 » Sun Apr 22, 2018 11:29 pm
You mean within APG or PTP?
by Destiny » Sun Apr 22, 2018 11:48 pm
APG.. Under Edit..
If its distorted in PTP, it might be your lens setting...
eric_5dmk2
Liked in: 5 posts
by eric_5dmk2 » Sun Apr 22, 2018 11:56 pm
I’ve recentered the pano in APG but did not used the straightening tool.
What is really odd is that, when opening the pano with other softwares, I do not have this issue...
by Destiny » Mon Apr 23, 2018 12:03 am
If your pano image is very small, you will get a small ball distorted effect in PTP.. The bigger the pano image the less distortion you will get.
eric_5dmk2
Liked in: 5 posts
by eric_5dmk2 » Mon Apr 23, 2018 12:11 am
I’ll try again and let you know
