Website Box plugin - how to interact with krpano?   [SOLVED] - View the solution
bitbyter
Liked in: 3 posts
by bitbyter » Fri Apr 13, 2018 2:18 pm
Hi, I'm trying to get a web page to appear (via website box) at the beginning of my tour to offer options - for example, if user indicates they are "business user" then activate some menu items that would normally be hidden.
When I launch the web page as a child window, the javascript I have in place can fire JS functions within the host window to successfully activate menu items. When I try launching this same page within website box, I can't figure out how to interact either with the host window or with the krpano engine directly.
Questions:
-is there any way that a page within "website box" can interact with the host page? references to window.parent, window.opener, and window.top all seem to fail
- is there a way I can reference the krpano functions directly from this page?
Thank you in advance! Scott
360-compunics-com-ni
Likes: 15 posts
Liked in: 163 posts
Re: Website Box plugin - how to interact with krpano?
by 360-compunics-com-ni » Fri Apr 13, 2018 8:39 pm
Something like this should work:
onclick="window.parent.krpano.call('closeKolorBox_websiteViewer();');"
or a locally defined function, served via php:
<a href=\"#\" onclick=\"window.parent.ShowMorePage('$More');\">
bitbyter
Liked in: 3 posts
Re: Website Box plugin - how to interact with krpano?  [SOLVED]
by bitbyter » Sat Apr 14, 2018 4:39 pm
THANK YOU THANK YOU THANK YOU Michael! "window.parent.krpano.call" was the answer. Appreciate your help!
360-compunics-com-ni likes this post.
