Invoke the mask plugin with a button or hotspot?
g_lab
Liked in: 5 posts
by g_lab » Sat Mar 10, 2018 6:50 pm
I'd like to switch different masks on and off with a button or hotspot. Is that possible?
Thanks,
g_lab
360-compunics-com-ni
Likes: 15 posts
Liked in: 163 posts
Re: Invoke the mask plugin with a button or hotspot?
by 360-compunics-com-ni » Sat Mar 10, 2018 10:08 pm
The plugin itself does not have these options, but you can hide/show the mask with the following code assigned to a togglebutton, using the advanced action "call custom code". If you don't already have that action, you can get it from http://www.kolor.com/wiki-en/action/view/Panotour_-_Advanced_-_Extra_Plugins#Call_KrPano_Code, just pay attention to the install instructions on top of the page.
Hide the current mask:
set(plugin[mask].visible,false);
Show it again:
set(plugin[mask].visible,true);
The plugin isn't multi-instance-capable, meaning you cannot include several instances having different masks. So changing the masks' skin is a bit more difficult but possible with custom coding.
@Kolor: how do you apply the different skins, as i don't see this as part of the plugin template file?
g_lab
Liked in: 5 posts
by g_lab » Sun Mar 11, 2018 12:57 pm
Thanks a lot! I'll try that custom code.
However It still would be great to have the possibility to switch different masks.
benji33 likes this post.
