Nadirpoint - Logo   [SOLVED] - View the solution
JoachimKP
Nadirpoint - Logo
by JoachimKP » Tue Nov 21, 2017 6:33 pm
Hello I put an photo with logo on the nadir patch. The logo is visible in the preview but not in the finished and renderd tour. I tried png and jpg format size in 100 percent. Any ideas what went wrong? Thank you!
Re: Nadirpoint - Logo
by Destiny » Tue Nov 21, 2017 9:51 pm
Hi... Did you try the 'Logo' Plugin... Heaps better... You can set it to the Nadir.... and even add a url.. Also, spin with the pano or fixed.. Quality is always better too..
2 people like this post.
by Destiny » Thu Nov 23, 2017 12:28 am
You will have access to all features after you add the Logo Plugin...
JoachimKP likes this post.
JoachimKP
Re: Nadirpoint - Logo  [SOLVED]
by JoachimKP » Thu Nov 23, 2017 9:20 pm
:) =D Hey Destiny Thank you very much for your help!!! It works
