3d animation merged in 360 rendering
barrubba
by barrubba » Wed Nov 15, 2017 10:06 pm
Hi.
I need to render a 360° camera in 3dsmax, and then insert some object moving in the scene.
Is that possible in 2 step?
Or i need to export an amount of 360 video render?
Re: 3d animation merged in 360 rendering
by Destiny » Wed Nov 15, 2017 10:56 pm
Hi... Not quite sure what you are trying to do... If its a matter of rendering a single 360 scene from the 3D Studio Max, then as long as use use the correct camera, for Pano rendering, it can be done easily. If you need 3D objects within that scene you will need to animate those object separately, and then link them to a Website Box, using WebGL is best or a sequence of images using a 3rd Party App.. PTP is not a 3D Pano environment.. However, Simlab Composer is..
Destiny....
Annis likes this post.
