Is it possible switching 3 languages with button?
bernardcustard
Likes: 12 posts
by bernardcustard » Sat Nov 04, 2017 7:13 am
Hi guys i tried to switching two languages with a toggle button and it works. I exported the tour in several languages and then i need a button that could have a dropbox with all the languages. Is that possible? how can i deal with 3 o 4 languages with a single button ?
It works perfect wiht two languages with the toggle button.
Many thanks in advance.
360-compunics-com-ni
Likes: 15 posts
Liked in: 163 posts
Re: Is it possible switching 3 languages with button?
by 360-compunics-com-ni » Sat Nov 04, 2017 5:47 pm
You can use the combobox-plugin needing some custom coding, see the documentation here: https://krpano.com/plugins/combobox/?version=116
The new krpano 1.19-pr13 version of KRPano, which unfortunately hasen't made it into current PTP yet (as of version 2.5.8), uses a new "combobox.xml"-plugin offering much more flexibility regarding the styling of the combobox, see an example tour here: https://krpano.com/examples/119/krpano.html?xml=examples/combobox/combobox-examples.xml.
bernardcustard likes this post.
bernardcustard
Likes: 12 posts
by bernardcustard » Sun Nov 05, 2017 12:00 pm
Thanks so much.i would try to digg and see which it´s the best option or easier. Thanks so much.
Likes: 15 posts
Liked in: 163 posts
by 360-compunics-com-ni » Sun Nov 05, 2017 6:00 pm
I just want to make clear that the new "combobox.xml" plugin that is demonstrated in the example tour does not work with the current PTP version, sorry if my post was misleading.
As you gave me the 100th "like" i decided to make the plugin, have sent it to you via PM ;)
Annis likes this post.
