Set tooltip above Point spot   [SOLVED] - View the solution
solarisx
by solarisx » Thu Aug 10, 2017 2:06 pm
Hi
How to set the text of the tooltip above the Point spot. Per default the text is below the Point spot.
Thanks in advance
Re: Set tooltip above Point spot
by Annis » Thu Aug 10, 2017 4:33 pm
Have a look at this user tutorial, the last section "3 CUSTOMIZED DISTANCE BETWEEN THE HOTSPOT AND THE TOOLTIP"
http://360cityguides.com/2016/03/28/pan ... d-tooltip/
solarisx
by solarisx » Fri Aug 11, 2017 11:53 am
Thanks Annis
I tried to set the yoffset from layer "panotourTooltipDefaultText" after the build. This does not work. Changing the color has no effect too.
I am using a modified Point Style which I saved in my library. The tooltip rule for desktop is "Permanent". May be there is another layer than the "panotourTooltipDefaultText" used? Any idea?
Greets
by Annis » Fri Aug 11, 2017 1:05 pm
Those are for normal hover tooltips.
Permanent tooltip's settings are just above it. So you'd have to change the alignment (from bottom to top) and see if you can add offset, but it looks like it will require much more extensive editing of the code than just the offset and unfortunately I don't understand this code enough to tell you precisely what to edit.
solarisx
by solarisx » Mon Aug 14, 2017 11:27 am
Thanks Annis,
maybe another one knows this?
Thanks in advance
Re: Set tooltip above Point spot  [SOLVED]
by benji33 » Wed Aug 23, 2017 1:54 pm
You can try to replace showPermanentTooltip(all); actions into the xml (yourtour.xml, yourtour_skin.xml and yourtour_core.xml files) by showPermanentTooltip(all,top,bottom);
Annis likes this post.
