gps indoor positioning and autogarrows
virtualdiorama
Likes: 3 posts
by virtualdiorama » Mon May 29, 2017 12:07 pm
Im thinking of buying the autogarrows plugin, it looks really good on paper, does anyone have some experience of using it?
Im using Nikon d800 and have a gps for it but gps doenst work indoors, do someone have a great low cost idea of how to get indoor positioning?
Best regards
johannes
Johannes Söderström
johannes.soderstrom@virtualdiorama.com
virtualdiorama.com
Re: gps indoor positioning and autogarrows
by Annis » Mon May 29, 2017 1:21 pm
I've given it a few quick tries and it seemed to work well. Though I don't have the latest version.
However for adding the GPS coordinates, you can place them manually in PTP or other software but retrieving them for each pano is another issue that I don't have a solution for. Perhaps you could base yourself on the floorplan of the house/building?
Not certain how this would work on several stories.
You could/should try contacting the author of the plugin, he might have some answers for you.
360-compunics-com-ni
Likes: 15 posts
Liked in: 163 posts
by 360-compunics-com-ni » Mon May 29, 2017 2:18 pm
If you are looking for a way to put your GPS data into the indoor panos, the free "exiftool" may be of interest.
You can write GPS data to multiple files as follows:
exiftool -GPSLongitudeRef=E -GPSLongitude=139.7513889 -GPSLatitudeRef=N -GPSLatitude=35.685 *.jpg
Example is for a Linux system, WIN and/or MAC may vary.
You can also apply GPS data from a GPS track log file, a valuable source of info is: http://www.sno.phy.queensu.ca/~phil/exiftool/geotag.html
