Panorama menu - Scale   [SOLVED] - View the solution
360panosi
Likes: 4 posts
Liked in: 7 posts
by 360panosi » Mon Jan 23, 2017 4:07 pm
In my virtual tour I'm using a Panorama menu, with I have some problem. On desktop and tablet version is the position of the Panorama menu (Offset x,y) right. But on my mobile iPhone 7 is the Offset of Panorama menu wrong, it's big and not in right place.
I wan't resolve this problem without: http://www.kolor.com/wiki-en/action/vie ... nt_devices
Any advice?
Re: Panorama menu - Scale
by Annis » Mon Jan 23, 2017 4:36 pm
No advice if you want to resolve the problem without the only solution.
None of Panotour's plugins are responsive.
360panosi
Likes: 4 posts
Liked in: 7 posts
by 360panosi » Mon Jan 23, 2017 4:39 pm
Annis wrote:No advice if you want to resolve the problem without the only solution.
Hm. I don't know, but how was resolve in this virtual tour http://www.stayinnlisbonhostel.com ?
by Annis » Mon Jan 23, 2017 5:08 pm
Custom coding, css, you name it.
There is one thing that does seem to have a large impact, by changing a few numbers in the html file which makes the viewport smaller, however since you don't want to edit anything there isn't anything I can suggest.
360panosi likes this post.
360panosi
Likes: 4 posts
Liked in: 7 posts
by 360panosi » Mon Jan 23, 2017 5:10 pm
When will be, if will, update for Panotour for responsive design?
Re: Panorama menu - Scale  [SOLVED]
by Annis » Mon Jan 23, 2017 5:13 pm
I couldn't tell you, I have no plan or ETA for new features, and while responsive plugins is high demand, there are many features on the features requests list.
If you want to know the html edit to be like http://www.stayinnlisbonhostel.com , this is it:
Open the html file in a text editor, find this line:
<meta name="viewport" content="target-densitydpi=device-dpi, width=device-width, initial-scale=1.0, minimum-scale=1.0, maximum-scale=1.0, user-scalable=no, minimal-ui"/>
Change the scales of initial-scale, minimum-scale, maximum-scale to something lower than 1. In the tour you linked, they're set to 0.5 to become:
<meta name="viewport" content="target-densitydpi=device-dpi, width=device-width, initial-scale=0.5, minimum-scale=0.5, maximum-scale=0.5, user-scalable=no, minimal-ui"/>
This will make the whole tour in general smaller on mobiles.
360panosi
Likes: 4 posts
Liked in: 7 posts
by 360panosi » Mon Jan 23, 2017 5:15 pm
Thnx for info.
