FATAL ERROR loading fail on local FILE EXPLORER Android.   [SOLVED] - View the solution
bernardcustard
Likes: 12 posts
by bernardcustard » Thu Jan 12, 2017 9:20 pm
Hi guys,
A few months or i don´t remember exactly i was able to reproduce virtual tours off line with ASTRO, and Android app that would able to reproduce the tour as i wanted, off-line and very fast. My surprise come that now it´s not working and it says that it has got a XML error. It works off line with computer (firefox, chrome) but it does not work with android. Any clue of what could happen. I´m running it on a Android Nougat 7.11 with a Nexus 6P and versions of Browsers are FIREFOX 50.1.0 and chrome version 55.0.2883.91
Thanks in advance and any clue that it brings me light it would be very welcome. By the way. Happy new year 2017.
Re: FATAL ERROR loading fail on local FILE EXPLORER Android.
by Annis » Fri Jan 13, 2017 1:33 pm
To view a tour offline you need to use a local webserver, otherwise it doesn't work correctly.
Is ASTRO a webserver app?
bernardcustard
Likes: 12 posts
by bernardcustard » Fri Jan 13, 2017 9:56 pm
I don´t know but it was working normally without any problem so it look that it was. https://play.google.com/store/apps/deta ... stro&hl=en
bernardcustard
Likes: 12 posts
by bernardcustard » Fri Jan 13, 2017 9:57 pm
Any recommendation for Android? Something like well known goodreader for ipad?
bernardcustard
Likes: 12 posts
Re: FATAL ERROR loading fail on local FILE EXPLORER Android.  [SOLVED]
by bernardcustard » Fri Jan 13, 2017 10:12 pm
I don´t know and why NOW it does not work Astro but it did. It´s working with another program that it´s a file explorer plus a cloud server https://play.google.com/store/apps/deta ... .pop&hl=en . You simple add the whole project into the mobile or tablet and then located with the program where it is and it works like a charm in firefox and android.
