krpano UltraLight Skin in Panotour
360panosi
Likes: 4 posts
Liked in: 7 posts
by 360panosi » Sun Mar 06, 2016 11:48 pm
It is posible to use krpano UltraLight skin in Panotour pro, like this one: http://krpano.com/tours/paris/?initvars ... ltra_light ??
This control bar is nice and has some effect, when hiding the bar....in Panotour I miss that...
Can I use this somehow with Panotour?
Re: krpano UltraLight Skin in Panotour
by Annis » Mon Mar 07, 2016 10:43 am
Edit your built tour to add the control bar.
If you want to use it as a a control bar from Panotour PRo, then you will have to recreate it as a control bar:
http://www.kolor.com/wiki-en/action/vie ... ontrol_bar
360panosi
Likes: 4 posts
Liked in: 7 posts
by 360panosi » Mon Mar 07, 2016 11:00 am
How can I do that exactly?
by Destiny » Mon Mar 07, 2016 11:33 am
Hi.. A very quick question but sad to say it needs a very long answer... Krpano and PTP are very different partially this skin.. The info Annis provided show how PTP menu needs to be made... Basically you need to start from scratch... Lots of work.. You will need a graphic editor such as Photoshop. But better to use a Vector Software like InDesign and then save as a bitmap such as a png when adding the final graphics into PTP.. The good news is, once made you can reuse it as many times as you like...
360panosi
Likes: 4 posts
Liked in: 7 posts
by 360panosi » Mon Mar 07, 2016 1:22 pm
Thnx, I understand that. But I was thought that can I maybe somehow simply use this krpano skin...... :/
by Destiny » Mon Mar 07, 2016 9:02 pm
Yes, that would be good... I have been trying to achieve that but I get errors.
