Little planet opening question   [SOLVED] - View the solution
360panosi
Likes: 4 posts
Liked in: 7 posts
by 360panosi » Fri Feb 05, 2016 9:24 pm
Hi everybody,
How can we add this type of rotation to start Little planet like this one:
https://dl.dropboxusercontent.com/u/106 ... /tour.html
but this one is created with krpano.
Likes: 14 posts
Re: Little planet opening question
by bdd » Mon Feb 08, 2016 2:37 pm
You cannot do it directly from Panotour Pro .
But once the tour is generated, open the xxx_core.xml file .
Find the action "setlittleplanet" :
  <action name="setlittleplanet">
    set(view.architectural, 0.0);
    set(view.hlookat, get(panoview.h));
    set(view.vlookat, 90);
    set(view.pannini, 0.0);
    if(panoview.fovmax LE 150,
      set(view.fovmax, 150);
      set(view.fovmax, get(panoview.fovmax));
    set(view.stereographic, true);
    set(view.fisheyefovlink, 1.5);
    set(view.fisheye, 1.0);
    set(view.fov, 150);
    events.dispatch(onStartLittlePlanetIntroduction);
  </action>
Change the line :
by :
    set(view.hlookat, 180);
Reload your tour in your browser.
You can then tune the value "180" to find the angle that fit your needs
2 people like this post.
