Saving current plugin settings as default
nagoyajin
by nagoyajin » Wed Oct 21, 2015 3:51 am
Is there a way to save current plugin settings as the default? For example, if I have modified the text in tooltips and want to always use the new text for that plugin, is there a way to save my work? I can save a all plugins as a preset, but what about individual plugins?
Cliquetsy
Likes: 106 posts
Liked in: 119 posts
Re: Saving current plugin settings as default
by Cliquetsy » Wed Oct 21, 2015 6:42 am
Not for individual plugins unless you edit the the original files to use your default settings. Which would be replaced on aa new install.
Consider creating a double if the plugin with your settings instead.
