GIS layers in the map plug in   [SOLVED] - View the solution
clairew90
by clairew90 » Wed Aug 19, 2015 11:47 am
I am working on a tour that I want to have geolocations on. I know how to do this, but as the tour is for a long tunnel, it will be underground so geolocating to a street map isn't very clear or helpful. I have a GIS file of the layout of the tunnels, so is it possible to have layers in the map function on the side of the tour? i.e. we could have the map but a layer beneath with the GIS file with geolocations linked to that? We should be able to get the latitude and longitude for points off the GIS layer.
To note, I am using 2.2.0 for an initial run and adding map features in 2.5 (had crashing problems with other versions for the tour building in the first place, but once a tour is built I can use 2.5 to add features)
Thanks for any help!
Claire
Re: GIS layers in the map plug in
by benji33 » Thu Aug 20, 2015 8:55 am
Hi Claire,
For the moment the map does support it. But some tests was done with KML.
clairew90
by clairew90 » Tue Aug 25, 2015 12:26 pm
Thanks for that - we have a kml layer embedded in a google map. What's the best way to have this map+kml layer come up in the finished tour? Is there an easy option in 'Build'?
Re: GIS layers in the map plug in  [SOLVED]
by benji33 » Wed Aug 26, 2015 9:44 am
You can try to update the YOURTOURdata > graphics > KolorBootstrap.js file to do it.
Into the initKolorMapOnReady javascript function look after these lines :
//register plugin
ktools.KolorPluginList.getInstance().getPlugin(pluginName).register(kolorMap);
And just before add this line :
kolorMap.addKmlOverlay("http://kml-samples.googlecode.com/svn/trunk/kml/time/time-stamp-point.kml", true);
Info : false deactivate the center on the KML
Then if working you can try with your own kml file. Kml must be stored online an use a absolute url, not relative.
