load different menue for mobile version   [SOLVED] - View the solution
mattkay11
by mattkay11 » Fri Jan 23, 2015 3:43 am
Hello everybody,
Is there the possiblity, that I can load a different menue when the tour is looked up with a mobile phone? (and another version of the menue when the tour is looked up with an Ipad)
I am using the Panorama Menue for my desktop tour, but for the mobile phone the menue is too big. It takes half of the screen of the phone. So I would like to have only one combo box with all the Panoramas in it to choose, when the tour is looked up with a phone.
OR - if that is not possible - is it possible to hide the menue with a button? The toggle button for example offers all kind of actions. It also offers "hide hotspots" but there is no option that says "hide menue"
Can it be done anyway? And if so - how?
Thank you very much!
mattk
Likes: 14 posts
Re: load different menue for mobile version
by bdd » Fri Jan 23, 2015 9:33 am
It can be easily done with some little modifications in the generated code.
1 / Build a tour for destop
2 / In the same project, do you modifications for mobile, and build the tour in a separate directory
3 / copy the "graphics" subdirectory of this second tour in the first tour
4 / rename the index_skin.xml file of this second tour in index_skin_mobile.xml and copy it in the first tour directory
5 / Open the index.xml file of the first directory
6 /Find the include of the index_skin.xml file. It looks like this :
  <!-- Plugins and Spot Styles -->
  <include url="%FIRSTXML%/index_skin.xml"/>
Change this line like this :
  <include url="%FIRSTXML%/index_skin.xml" devices="desktop"/>
  <include url="%FIRSTXML%/index_skin_mobile.xml" devices="mobile|tablet"/>
Jeremiahscott likes this post.
Virtuel Rundtur
by Virtuel Rundtur » Fri Jan 23, 2015 10:06 am
It can be done even more user friendly :-)
I have created two versions of the original panoramaMenu plugin.
One for mobile and one for Tablet and desktop.
Just install the attached plugins in your user directory and restart Panotour.
It is now possible to create a menu that only shows up on a mobile and another that only shows up on tablets and desktops.
No need to edit XML files after building the tour and save two different versions ;-)
Best regards
Henrik
2ver_panoramaMenu.zip
(26.51 KiB) Downloaded 140 times
Virtuel Rundtur
by Virtuel Rundtur » Fri Jan 23, 2015 10:19 am
Btw. the same can be done to the controlbar plugin, if you need bigger buttons for mobile...
mattkay11
by mattkay11 » Mon Jan 26, 2015 6:21 am
ahhh no :( it seems it took me too long to reply, I got logged out and well.. here we go again...
Thank you very much for your replies!
I downloaded the plugins and installed them. But it did not help me a lot because my tour is so big, it has so many panoramas, that even when I show a smaller version of the Panorama Menu it will not fit on a mobile phone.
What I need for the mobile phone is the combobox version of a menu. It is a dropdown menu where all groups and panos are combined in one. For a better understanding please have a look at the 2 screenshots I attached.
With the plugin you put online to download (thank you for your great work), I can only modify the Panorama menu.
It would be great, if I could also choose between different types of menues I want to show (like combo box, drop down, pano menu...).
Is this possible?
Likes: 14 posts
by bdd » Mon Jan 26, 2015 11:01 am
Then you can use the Panorama Menu from Virtuel Rundtur, and a classic combobox.
And when the tour is built, apply the same modification as the one he did in his plugins.
Find the following "events" XML node
<events name="combopanolistallpanoramasStartTourEvents" onTourStart="set(layer[combopanolistallpanoramas].isStarted, true);if(layer[combopanolistallpanoramas].isLoaded,combopanolistallpanoramasShow(););" keep="true" />
And modify it like this :
<events name="combopanolistallpanoramasStartTourEvents" onTourStart="set(layer[combopanolistallpanoramas].isStarted, true);if(layer[combopanolistallpanoramas].isLoaded,combopanolistallpanoramasShow(););" keep="true" devices="tablet|mobile"/>
Virtuel Rundtur
Re: load different menue for mobile version  [SOLVED]
by Virtuel Rundtur » Mon Jan 26, 2015 11:02 am
That can easily be done.
I have also made a "Mobile only" version of the Combox plugin.
It is quite simple to make your own versions of the plugins.
Just add:
devices="desktop|tablet"
or
devices="mobile"
in the events tag on the tmpl file of the plugin. Don't forget to update the plugname of your new plugin
If you need to have two versions of a plugin in the tour (One for mobile and one for desktop) you also need to rename the plugin name in the xml file, since plugins can't have the same name twice.
I have added to new categories in my style tab. One called: "For mobile only" and another "For desktop only" In that way it is easy to build a single tour that looks good on both smartphones, tablet and desktops.
Enjoy!
// Henrik
Virtuel Rundtur
by Virtuel Rundtur » Mon Jan 26, 2015 11:24 am
Ooopss
I forgot to attach the plugin...
Here we go
// Henrik
MOBILEpanoramaCombobox.zip
(6.36 KiB) Downloaded 113 times
mattkay11
by mattkay11 » Mon Jan 26, 2015 2:48 pm
Henrik you are awesome!
Thank you very much! It works just fine.
I just had to change the code in the plugin a little as it does not work like you put it online.
Your Code says:
<plugin id="mobilepanoramacombobox" category="tr:For mobile only" name="tr:Mobile Panorama Combobox" version="1.3" isGraphical="true" multipleInstance="true" description="tr:Drop down list containing the panoramas">
  <parameters>
But it should be
<plugin id="mobilepanoramacombobox" category="tr:Menu" name="tr:Mobile Panorama Combobox" version="1.3" isGraphical="true" multipleInstance="true" description="tr:Drop down list containing the panoramas">
  <parameters>
So "Menu" instead of "For mobile only"
all the best!
mattk
Virtuel Rundtur
by Virtuel Rundtur » Mon Jan 26, 2015 2:56 pm
You are welcome :-)
The reason for the "For mobile only" category, is that I like to group the "Mobile only" plugins on my plugins list in the style view.
mattkay11
by mattkay11 » Mon Jan 26, 2015 3:01 pm
I see, nice one :) I just sent you an Email, hope it is also useful to you.
br
mattk
ptira
by ptira » Thu May 21, 2015 5:20 pm
the tricks offered by Virtuel Rundtur for Panorama Menu works fine but does not go for Simple Button / Toggle Button plugin.
I need to have two versions of a plugin in the tour (one for the mobile and one for desktop) but not work.
What to do?
by Annis » Fri May 22, 2015 10:59 am
ptira wrote:Hello,
What to do?
When modifying the plugin, make sure that you rename the "plugname" to something different, for example add "mobile" to the name. It's the plugin's ID in the built tour so if you have one normal button and one modified but they both have the same ID they will cancel each other out and only the last one in the xml will be used.
CUsersAnnis-DocumentsKolorPanotourPro 2pluginsmobilebuttonbutton.tmpl - Notepad++.png
The same modification should be done to the mobile only combobox listed higher up.
ptira
by ptira » Sat May 23, 2015 3:36 am
Yes !!
After rename the "plugname" It works very well ...
Thank you very much Annis for the clarification and the response speed.
FunkyPunky
Likes: 10 posts
Liked in: 4 posts
by FunkyPunky » Sun Jun 07, 2015 9:56 am
i just try Géralds tip:
bdd wrote:It can be easily done with some little modifications in the generated code.
My question regarding point 3 is: Have i to overwrite the graphics folder in the first tour output or have i to rename the new graphics folder in graphics_mobile?
Thanks!
by benji33 » Tue Jun 09, 2015 2:19 pm
Overwrite.
Always keep a backup of your first work and kpt version to be able to recover your tour in the last good step.
FunkyPunky
Likes: 10 posts
Liked in: 4 posts
by FunkyPunky » Tue Jun 09, 2015 7:24 pm
Thanks, Benjamin!
