How far away is Panotour 2.4?
Virtuel Rundtur
by Virtuel Rundtur » Thu Jan 15, 2015 4:30 pm
Hi Kolor team
Just got my Zeiss VR One today, and i am very excited about it.
I would really love to create virtual tours like this:http://krpano.com/stereo3d/indiantemple/mobilevr.html, but in non 3D...
I love the way you navigate through the scenes...
Will PTP 2.4 support something like this, and when will the first Beta be available?
I have a client, that could really use this on a exabition next month...
Best regards
Henrik
Re: How far away is Panotour 2.4?
by benji33 » Fri Jan 16, 2015 9:26 am
2.4 is not ready for beta yet.
But you can try a part of the VR headset export (unfinished) with a registry edit into the 2.3.1 version.
For windows :
1. Close Panotour Pro
2. With regedit go to HKEY_CURRENT_USER > Software > Kolor > Panotour Pro 2.3 > general
And edit or add the "internal" key with value "2".
3. Launch Panotour Pro. A new button appears on the build screen to give ability to build a tour for mobile vr headset.
For MacOSX :
Do the same with the Panotour Pro 2.3.plist into preferences.
Notes:
- This is not a finished feature, you are testing this at your own risk.
- You must only use full 360x180° panoramas
- All the plugins are removed from your tour when using this plugin, to add use of the Gyro it must be added manually to the xml files.
Here is a demo of the export: http://bilbao360walk.com/vr/
FunkyPunky
Likes: 10 posts
Liked in: 4 posts
by FunkyPunky » Fri Jan 16, 2015 9:36 pm
Oh, that sound interesting for me too!!!
The path is user/library/preferences/com.kolor.Panotour Pro 2.3.plist, right? Where have i to enter what exactly? Benjamin, please could you describe more detailed whatto do for OSX, please?! Thanks!
by Annis » Mon Jan 19, 2015 10:53 am
It will be in the same place in the .plist
You'll need software like XCode or Prefs Editor to edit the .plist.
Let me just remind you that the export option you are about to try is unfinished.
FunkyPunky
Likes: 10 posts
Liked in: 4 posts
by FunkyPunky » Tue Jan 20, 2015 10:42 am
Thanks Annis! Works! :-)
At the moment its a solution to output a ordinary (2D) project for VR headsets. Is there a possibility to do that with a real stereo pair of panoramas (input of two different equis and output as side-by-side)?
Will there be a solution in the next release of PTP?
Thanks!
slivovitsa_1975
Likes: 8 posts
Liked in: 7 posts
by slivovitsa_1975 » Tue Jan 20, 2015 1:18 pm
Unfortunatelly, it looks less easy than expected. :-(
I generated the HTML files and try to open it (via www or saved on the samsung S5) and a black screen is displayed...
Do I have the change some settings? there is only 2 pano and 1 link in each one.
http://www.vebi.be/test/Google.html
Pierre
Pierre
pano Giga & Panotour Pro
D800 + Nikkor 10,5
Likes: 14 posts
by bdd » Tue Jan 20, 2015 2:26 pm
slivovitsa_1975 wrote:Unfortunatelly, it looks less easy than expected. :-(
Pierre
Many files are missing on your server.
3 Javascript files at least :
http://www.vebi.be/test/VVI-3Ddata/lib/ ... 1.1.min.js
http://www.vebi.be/test/VVI-3Ddata/lib/ ... ols.min.js
http://www.vebi.be/test/VVI-3Ddata/grap ... otstrap.js
Re-upload the missing files and check your tour then,
by benji33 » Tue Jan 20, 2015 3:06 pm
FunkyPunky wrote:Thanks Annis! Works! :-)
Thanks!
Yes only 2D.
Stereo will not be available before a redesign of the groups to be able to generate a left and right eyes main groups.
Virtuel Rundtur
by Virtuel Rundtur » Sat Jan 24, 2015 3:39 pm
It wont work here either.
Got the VR headset checkbox, but only thing that shows up on my iPhone is a black background with a white box with some missing images and links to VR-mounts.
http://taaning.dk/test3
I have added the Gyro plugin in the style tab, which i guess is required..
Do we need a special html template?
by benji33 » Mon Jan 26, 2015 1:52 pm
404 error for your page http://taaning.dk/test3
Gyro plugin must be added manually (for the moment) because all plugins are removed on this kind of generation.
Also panorama must be 360x180.
