Choosing gear & software for virtual visits
gringollanero
by gringollanero » Wed Oct 26, 2016 2:47 pm
Basically a mewcomer in the world of virtual visits 360 (for real estate purposes mostly), but quite familiar if not savvy with Autopano Giga and even more with Photoshop, I would very much like to know whether I would be better off using an already purchased ultra wide angle lens of the 14-28mm range, or getting a cheap but quite decent fisheye lens (Samyang for instance), or else an all-in-one kit like Giroptic, Samsung, Ricoh… that will do a quick and possibly not too dirty job, saving time. I reckon that ultimate quality is not at stake at this stage, just for virtual visits of apartments.
In case I should opt for the higher quality, is a fisheye lens much easier to stitch than an ultrawide angle which Arnaud Fritch seems to point out), using Autopano Giga which I own anyway? I never found pictures stitching taken with an ultawide angle very convincing or easy, even with a large overlapping area bteween frames while with standard or tele lenses it is done in a breeze. Have I missed something or is the eye very forgiving when it comes to virtual visits?
Also, has Panotour any use for the strict stitching function or is this the Autopano Giga’s sole realm?
Very grateful for any answer bridging the gaps in my present concept and in getting equipped.
