Correct Lens Distortion in Lightroom or Autopano?   [RESOLU] - View the solution
dfindlay
by dfindlay » Wed May 18, 2016 3:10 am
Always been confused about this. If I apply lens distortion correction to images in Lightroom, what happens when they are imported to Autopano Giga? Does Autopano attempt to correct them again and thus produce another distortion?
What is the accepted workflow for handling distortion?
Thanks.
olivierbo
Liked in: 134 posts
Re: Correct Lens Distortion in Lightroom or Autopano?  [RESOLU]
by olivierbo » Thu May 19, 2016 1:56 pm
By default, the distorsion is set to default which means that Autopano decides by itself if it is necessary to apply a distorsion calculation or not (barrel or pincushion).
You can also set this option to "Do not optimize" but not necessary in most of the cases.
Kind regards,
Olivier
dfindlay
by dfindlay » Thu May 19, 2016 5:18 pm
Thank you Oliver.
