Device Check or Manual copying mobile_skin.xml?
All things panoramic.
ijarboe
by ijarboe » Thu Mar 08, 2018 5:19 pm
Hello everyone,
I'm kind of torn in between my workflows at this point and maybe someone out there can shed some light as to a possible solution. I bought the device check plugin thinking it would solve this issue. I would like to keep everything in one panotour file if possible but one issue I have while running into mobile and desktop versions is that if I have to change anything in either version such as a text edit does that affect the mobile_skin.xml?
One reason I bought device check was so I could keep everything in one tour and make edits there and not have to rebuild a mobile version. I was hoping I could "show" the description on the desktop version at 20% width and on the mobile version at 45% width after people click on a hotspot. You can check it out here http://ellenbrowningdesign.net/listing/church/ which it shows up fine it is just there are some text edits that need to be done. Sorry for the long descript. I'm not used to writing a forum
360-compunics-com-ni
Likes: 15 posts
Liked in: 163 posts
Re: Device Check or Manual copying mobile_skin.xml?
by 360-compunics-com-ni » Fri Mar 09, 2018 9:42 pm
i have replyed to your private message clarifying the usage instructions, hope that helps.
If there are still problems send me a mail or use the plugin's thread: https://www.kolor.com/forum/viewtopic.php?f=40&t=37446
Best wishes,
Michael Brüning
