AVP 3 - DWARP "Unsupported Rig configuration"
pzd3mir
by pzd3mir » Tue Jul 17, 2018 2:10 pm
I just bought the upgrade from AVP 2.6 to 3.0 to use the DWarp feature. I got a Brahma7 + 1 RIG consisting of 8 cameras in total. I use Git2 action cam.
I get this error when trying to compute DWarp:
olivierbo
Liked in: 134 posts
Re: AVP 3 - DWARP "Unsupported Rig configuration"
by olivierbo » Wed Jul 18, 2018 8:51 am
D.WARP can be used with any RIG with 3 or more cameras, but we cannot confirm it will be compatible with ALL the RIG of the market as it is a specific algorithm. We have just tested D.WARP with some common RIGs available on the market. So, I we can't test all the configurations available on the market, wWe recommend to test the software before to be sure it will suits your needs.
Let me know if you have any question.
Best regards,
Olivier
pzd3mir
by pzd3mir » Wed Jul 18, 2018 10:10 am
Do you know what causes the error? Is it possible to make it work somehow or if not, are you going to put any efforts to make it work for the configuration I have? Can I provide you with data to make it easier?
olivierbo
Liked in: 134 posts
by olivierbo » Wed Jul 18, 2018 10:22 am
Can you tell me if you are able to stitch your video properly (synchro OK or not, stitching quality, improving quality into Autopano Giga, etc)? D.WARP is the very latest option to use if you are not able to stitch the project properly.
Let me know.
Best,
Olivier
pzd3mir
by pzd3mir » Wed Jul 18, 2018 3:00 pm
Yes, all of that works. Sometimes it doesn't and I need to restart but then it does work again. I wanted to use DWarp for moving objects and when the camera itself moves.
olivierbo
Liked in: 134 posts
by olivierbo » Fri Jul 20, 2018 10:39 am
So, DWARP default preset may work (Prioritize space).
Could you share or send your footage? How long is it?
Kind regards,
Olivier
ctgsproductions
by ctgsproductions » Mon Aug 20, 2018 3:31 pm
Bonjour Olivier.
Could you please tell me if the Samsung 360 Round with 17 lenses is compatible with AVP 3? It seems that the D-warp tool only functions with rigs that have 13 or less lenses. We have another rig with 14 Gopro's that wont work with D-warp.
Merci pour repondre,
Salutations.
Ulrich Vilbois
olivierbo
Liked in: 134 posts
by olivierbo » Mon Aug 20, 2018 3:44 pm
Hello Ulrich,
I absolutely do not know, I'm sorry. If you can get some footage to test...
Cheers,
Olivier
ctgsproductions
by ctgsproductions » Mon Aug 20, 2018 6:17 pm
Let's put it this way, how many lenses will AVP 3 D-Warp will function with? No matter what rig.
Merci.
olivierbo wrote:Hello Ulrich,
Cheers,
Olivier
olivierbo
Liked in: 134 posts
by olivierbo » Tue Aug 21, 2018 7:16 am
D.WARP can work with any RIG with 3 or more cameras but we cannot confirm it will work with your RIG; The algorithm is specific and cannot work all the time.
Cheers,
Olivier
ctgsproductions
by ctgsproductions » Tue Aug 21, 2018 5:56 pm
I do not think that the configuration of the rig matters. D-warp seems to work with a limited amount of cameras only. Have you made a test with any rig with more than 14 cameras?
Thank you.
olivierbo
Liked in: 134 posts
by olivierbo » Wed Aug 22, 2018 7:15 am
No we don't!
Olivier
ctgsproductions
by ctgsproductions » Wed Aug 22, 2018 4:34 pm
Is Kolor working on fixing the issue? I have purchase AVP 3, mostly because of the D-Warp upgrade. A bit disappointed, I have to tell you. Many professional companies are using 3d rigs now, that requires 14 lenses or more. I would strongly recommend your team to look at some option to fix the issue.
Best regards,
Ulrich.
