APV not rendering Cineform MOV
SoenkeW
Likes: 4 posts
by SoenkeW » Thu Jul 12, 2018 9:09 am
Hi Folks,
we have just installed APV 3.0 on a new machine (Win8.1 Pro, Xeon E5-2687W 3GHz, 256GB Ram, Nvidia Quadro M6000 24GB). I wanted to render a project, that was stitched on another machine to speed up workflow. But for some reasons, that machine does not render the quicktime file.
However it does write a file, but after many hours file size still is at 0KB. However it does render MP4 into the exact same place with the exact same name, but does not render mov. The machine, where the project was stitched on, does render mov...
Batch renderer gets stuck in startring computations, prompting "RENDERER: CPU [Forced]". When trying to stop rendering, AVP3 crashes.
Do you have any ideas, how to solve this?
Best regards,
Sönke
SoenkeW
Likes: 4 posts
Re: APV not rendering Cineform MOV
by SoenkeW » Thu Jul 12, 2018 10:15 am
I have just checked with other projects,and there is the same problem. As mentioned, rendering on my other machine (with the same setup) works...
Any ideas?
orbe360
by orbe360 » Fri Jul 13, 2018 4:36 am
Same problem here, im waiting that the kolor team give us a solution for this MAJOR ISSUE
orbe360
by orbe360 » Fri Jul 13, 2018 4:38 am
If someone find a solution please post it
SoenkeW
Likes: 4 posts
by SoenkeW » Fri Jul 13, 2018 8:25 am
I am actually trying to reinstall, as on the other workstation (as mentioned: same config) there is no problem rendering... Will let you know, what happened...
orbe360 likes this post.
orbe360
by orbe360 » Sat Jul 14, 2018 12:06 am
I recive this mail from Kolor team
Hi Rodrigo,
Sorry for the inconvenience. First of all: please do not install codec pack on your computer, it might completely break AVP configuration.
Can you please try the following things:
exporting in another file format (H264, ...)
change GPU mode into the preferences to « GLSL engine »
make sure that the output directory still exists -> try to export to your desktop
After that mail i delete the K Lite codec pack and export the video to my desktop and good news
IT WORKS!!
At least in the scene that I try it work...
SoenkeW
Likes: 4 posts
by SoenkeW » Mon Jul 16, 2018 7:36 am
Good to hear!
For me it is no help, as I don't have any additional Codec Packs installed. Uninstalling and new Instalation was no help, as well.
Oddly, rendering mp4 into the same directory does work!
