Autopano Video with Vuze+ VR Camera
dittytv
by dittytv » Tue Mar 27, 2018 2:19 pm
Any advise/tips on using Autopano Video with our Vuze+ VR Camera? Thanks in advance.
olivierbo
Liked in: 134 posts
Re: Autopano Video with Vuze+ VR Camera
by olivierbo » Wed Mar 28, 2018 10:46 am
What kind of issue do you encounter?
What you can do is after you stitched your video, Autopano Video creates JPEG pictures that are used to create a reference panorama. You can add those pictures to Autopano Pro/Giga, check image properties (focal and lens type), detect the pano, make some stitching improvements if needed, then save the project (.pano) and use it to stitch your videos in Autopano Video (Stitch as: Template panorama).
Let me know if it helps.
Best,
Olivier
WayneBG
Likes: 8 posts
Liked in: 3 posts
by WayneBG » Fri Apr 20, 2018 11:30 pm
Use FFMPEG to separate the 8 cameras video into separate files.
It can help to correct the 3D alignment for each 3D pair before stitching. I do this in Vegas.
I have created a Vuze preset for AVP & find it works well for the Vuze+ too. I'll attach it to this post.
Vuze_WBG.xml
(388 Bytes) Downloaded 322 times
If you do Facebook, I have posted more information in the Vuzers - Vuze VR Camera Users FB group.
If not, let me know and I'll share more info here.
