VR Plugins will not give my box to to select on Install
kendallmartin
by kendallmartin » Wed Jul 05, 2017 11:11 pm
I feel like this is a commonly asked, rarely answered question around the use of Kolor software. I can't get the check box that allows me to install the GoPro VR plugins in Premiere when I install ANY version of Kolors Autopan trial software. I'm literally an ex-gopro exployee and I worked as a full time editor and worked on VR footage using these plugins, but apparently I can't install them on my own without a GoPro Media IT guy by my side. Someone help!
olivierbo
Liked in: 134 posts
Re: VR Plugins will not give my box to to select on Install
by olivierbo » Thu Jul 06, 2017 10:34 am
Is Premiere installed on the same partition than AVP? Which version of AVP have you tried to install and version of Premiere present on the system (CC2015 as a minimum)?
Best,
Olivier
kendallmartin
by kendallmartin » Fri Jul 07, 2017 12:39 am
Yeah,
Everything is installed on the same partition. I have Premiere CC. and I'm downloading the most recent version of AVP. I believe it is 2.6.2 No clue why it won't give me the check box on install.
olivierbo
Liked in: 134 posts
by olivierbo » Fri Jul 07, 2017 10:48 am
Have you removed any other version of AVP, including beta, alpha, or RC?
When AVP installs the plugins, you have 2 .prm files in C:\Program Files\Adobe\Adobe Premiere Pro CC 2017\Plug-ins\Common\GoPro\GoProVRHorizon.prm @ GoProVRReframe.prm
Best,
OLivier
kendallmartin
by kendallmartin » Fri Jul 07, 2017 5:37 pm
When I installed it I had no previous versions, and each additional time ive attempted to install, I have first uninstalled the previous versions. Would having a PC make a difference? It seems that I am not getting the "GoPro/GoProVRHorizon.prm" path installed on my computer. When I open the "common" folder, the only other folders in there are "VST3" and "Effect Presets" as well as a list of premiere pro effect/plugin files. No GoPro folder or GoPro PRM files.
-Kendall
olivierbo
Liked in: 134 posts
by olivierbo » Mon Jul 10, 2017 11:47 am
Hello Kendall,
I do not know why the installer does not detect your app. Have you tried on another system?
I can send you the plugins for Windows and OSX to be copied manually.
Please, let me know.
Best,
Olivier
kendallmartin
by kendallmartin » Mon Jul 10, 2017 6:19 pm
Hello Olivier,
No, I can't use another system. I only have one computer. If you can send it, that would be great!
kendallmartin
If you can tell me how to copy it manually that would be great too!
