Rendering stuck at 99%
martind
by martind » Thu Jun 08, 2017 9:17 am
I am using Autopano Video Pro.
When i start to Batch Render, the render engineoften stucks at 99%.
I searched for the problem and found that this problem should have been solved with version 2.3.1 already.
Any suggestions what i can do to solve this issue?
olivierbo
Liked in: 134 posts
Re: Rendering stuck at 99%
by olivierbo » Fri Jun 09, 2017 1:21 pm
Which version of AVP are you using exactly? Does it occur with all the videos?
Try to select Authoring tab before you render.
Best regards,
Olivier
martind
by martind » Fri Jun 09, 2017 11:15 pm
thanks for reply. I am using Autopano Video Pro 2.6.2 64bit. It occurs very often but not always. It also occurs when using batch rendering.
regards
Martin
olivierbo
Liked in: 134 posts
by olivierbo » Wed Jun 14, 2017 8:42 am
Hi Martin,
If you select Authoring tab before rendering? Also, if you can test with AVP 3.0 currently available as an Alpha 3. Finally, do you have another system you can use to test?
Thanks in advance
Olivier
