AutoPano Video & Giga -> crop doesn't work ....
just
by just » Thu May 25, 2017 12:01 am
Hi All,
When I crop the video in the Giga, the changes are not reflected in the Video Pro. Why? Any other changes are do reflected (rotate, etc). Should I uncheck a 'keep ratio' in some place? where?
Thank you!
olivierbo
Liked in: 134 posts
Re: AutoPano Video & Giga -> crop doesn't work ....
by olivierbo » Tue May 30, 2017 1:36 pm
You must select "Authoring" tab in the timeline in order to have your modification saved. Then, you will see a "Custom ratio" in the list.
Cheers,
Olivier
just likes this post.
polarity
by polarity » Sat Jun 03, 2017 11:46 pm
Hi Olivier,
I have a similar problem to this. When I mask in Giga, it is not changing in AVP. I am on the authoring tab and all files are in the same folder. When I click save it looks like it is doing something with processing icon, but I still have a face cut up where it crosses 3 cameras. The masking isn't being applied in AVP. Am I missing something?
Thanks,
Simon
olivierbo
Liked in: 134 posts
by olivierbo » Tue Jun 06, 2017 12:12 pm
You cannot see any effects of your masks because you are using a smooth blending (DIAMOND), so in APG go into the blend icon, blending: multiband, level -2, cutting ISO, no Weighting. In AVP, blend -> sharp.
Let me know.
Best,
Olivier
just
by just » Wed Jun 07, 2017 9:10 pm
I did all as you recommended, but it still doesn't work... Please see below the settings, which I used.
APV settings:
APG settings:
So, what's wrong?
Thank you!
olivierbo
Liked in: 134 posts
by olivierbo » Thu Jun 08, 2017 8:34 am
For the mask tool, you must select Stitching tab as stated in our documentation.
Best,
Olivier
polarity
by polarity » Thu Jun 08, 2017 4:29 pm
Had this problem using AVP 3 Alpha 2 version, have reverted back to Alpha 1 version and is now working - although quite unstable, naturally for Alpha stage.
