CineForm plugin for VLC
Emeric
Likes: 3 posts
Liked in: 14 posts
by Emeric » Wed Apr 27, 2016 9:36 am
This is a CineForm HD encoding/decoding plugin for VLC
It will allow you to watch CineForm encoded videos in VLC.
More information here: http://www.kolor.com/2016/06/07/introdu ... n-for-vlc/
Requirements
VLC versions 2.2.0 to 2.2.4 are supported
Windows: Choose the correct plugin version depending on the VLC version you have installed, NOT your OS architecture
Mac OS: You will need the official VLC.app package installed in your /Applications directory
Downloads
Go to the official download page: http://www.kolor.com/cineform-vlc-plugin/
Any comments, thoughts or reports? Post them here and only here, thanks!
Release notes
Version 1.0
- initial release
vincen likes this post.
TomVR
Liked in: 5 posts
Re: CineForm plugin for VLC
by TomVR » Fri Jun 17, 2016 4:06 pm
When is cineform .mxf coming? It's not safe to use .mov on windows anymore.
Emeric
Likes: 3 posts
Liked in: 14 posts
by Emeric » Tue Jun 21, 2016 10:00 am
Hi, I never came across any CineForm/mxf file, could you maybe send me a short sample?
Also, I guess you're assumption about "unsafe .mov on windows" is based on the quicktime software support being discontinued? Quicktime is the one that's unsafe in this story, not the .mov file format.
vincen
Kolor Certified Trainer
Likes: 23 posts
Liked in: 4 posts
by vincen » Fri Jun 24, 2016 10:59 am
Emeric wrote:Requirements
• VLC versions 2.2.x are supported
Linux version avalaible ?
Blog: http://www.skivr.com
Emeric
Likes: 3 posts
Liked in: 14 posts
by Emeric » Thu Jul 07, 2016 9:26 am
Actually yes, the next release will get linux support, but without an installer or anything so for experienced users only.
y88cdw
by y88cdw » Thu May 18, 2017 6:18 am
2.2.X compatibility is not correct. Plugin works up to 2.2.4. Version 2.2.5.1 is not supported.
Annis likes this post.
vincen
Likes: 23 posts
Liked in: 4 posts
by vincen » Thu May 18, 2017 6:34 am
Emeric wrote:Actually yes, the next release will get linux support, but without an installer or anything so for experienced users only.
Still not avalaible for Linux ??
bkamphues
by bkamphues » Wed Jun 07, 2017 12:04 am
I am experiencing a problem installing the CineForm plugin for VLC. I have chosen the correct installer for my VLC installation, but it won't recognize the plugin inside VLC. I have looked through my installation directory and found the files for the CineForm plugin. I'm guessing that it should automatically work after installation of the plugin, but on my side it won't. Any fixes?
by Annis » Wed Jun 07, 2017 1:11 pm
@bkamphues Which version of VLC are you using?
Seemingly the plugin does not work beyond v2.2.4, and we unfortunately do not have an update planned for anytime soon.
bkamphues
by bkamphues » Wed Jun 07, 2017 1:52 pm
Yeah I managed to downgrade to 2.2.4 which was the problem. Works great now!
trevorjharris
by trevorjharris » Thu Sep 07, 2017 10:46 pm
I have install vlc 2.2.4 (64 bit) on windows 7 with cineform codec. Plays cineform on. When I try to encode a file The cineform codec is not an option. Please can you tell me how to encode cineform.
gooseodyssey
by gooseodyssey » Sat Oct 21, 2017 4:11 pm
When I preview CineForm files in VLC using this plugin, the videos are ever so slightly pixelated. Noticeable on edges. When I view them in QuickTime 7 they're fine. Any ideas?
Eric Fassbender
Likes: 4 posts
by Eric Fassbender » Wed Feb 28, 2018 12:20 pm
Are there any plans to port the plugin for newer versions of VLC? E.g. v 3.0 Vetinari?
Cheers,
Eric
Atmosphaeres
leandroprz
by leandroprz » Wed Apr 11, 2018 5:46 pm
Eric Fassbender wrote:Are there any plans to port the plugin for newer versions of VLC? E.g. v 3.0 Vetinari?
Cheers,
Eric
Came looking for this same answer. Any updates on this?
