Plugin: DeviceCheck
360-compunics-com-ni
Likes: 15 posts
Liked in: 163 posts
Plugin: DeviceCheck
by 360-compunics-com-ni » Tue Dec 12, 2017 7:31 pm
There is a new PanotourPro plugin available that lets you select on which device types (Desktop, Tablet and/or Mobile) you want to hide (or display) other PTP plugins. Using multiple instances of this plugin you can configure different device specific layouts within one tour.
The DeviceCheck plugin works with the following PTP plugins:
    Simple Button
    Toggle Button
    Panospecific Simple Button
    Panospecific Toggle Button
    Description
    Title
    Logo
    PanoramaMenu
    Floorplan
    PanotourMaps
    Call actions on tour events (CAOTE)
The DeviceCheck plugin also works with the following PTP controlbars:
    classicControlBar
    dockedThumbsControlBar
    iControlBar
    urbanControlBar
    D-padControlBar
    roundCornerBar
    CirclesControlBar
    SansControlBar
Please note the "Known issues/restrictions" information that is part of the plugin documentation available at: http://dev.compunics.com.ni/
The price of this plugin is 44€ (including tax) payable via Paypal.
Edit:
V1.1 2017-12-14 Added support for panoramaMenu plugin
EDIT 2018-01-03: Version 1.1 has been tested successfully with PTP V2.5.9
EDIT 2018-01-08: Version 1.2 is out, now the 'Call actions on tour events (CAOTE)'-plugin can be disabled on device types
3 people like this post.
bobjones
Likes: 8 posts
Liked in: 8 posts
Re: Plugin: DeviceCheck
by bobjones » Sat Mar 10, 2018 1:32 am
I need coloured areas, headers, footers and progress bars.
If you are planning to include these, can you please update here when these are added?
Likes: 15 posts
Liked in: 163 posts
by 360-compunics-com-ni » Sat Mar 10, 2018 5:26 pm
Hello bobjones,
thanks for your interest.
coloured areas, headers, and footers are already on my ToDo-list, i will have a look at the progressbar also and let you know.
Best wishes,
Michael Brüning
Likes: 15 posts
Liked in: 163 posts
by 360-compunics-com-ni » Sun Mar 18, 2018 9:33 am
Version 1.5 is out, DeviceCheck now also supports the following standard PTP plugins:
header, footer, colored Area and progressBar&Loopings
In addition, you can now also hide the "Clean buttons controlbar".
As usual, exisiting DeviceCheck-users get the update for free.
bobjones
Likes: 8 posts
Liked in: 8 posts
by bobjones » Sat Mar 24, 2018 5:49 am
I just picked up DeviceCheck because of the addition of these new features. I really appreciate the update Michael.
I have to say... This *SHOULD* be a built in feature of Panotour. Every plugin in Panotour should have these desktop/tablet/mobile check boxes. It's mind boggling why they have not made it easier to create mobile interfaces. It's a huge hassle and waste of time for it's users to create separate mobile versions and then hand code it in after every build and I've been waiting for this feature to be implemented for years!
I'm doing 8 interfaces for a picky client right now who constantly wants tiny changes.
This plugin has saved me a huge amount of time and headaches making separate mobile versions every time they want a change.
Thanks so much for your hard work developing it!!!
Likes: 15 posts
Liked in: 163 posts
by 360-compunics-com-ni » Sun Mar 25, 2018 5:06 pm
Hello bobjones,
i'm glad that the plugin helps you in making your tours efficiently, thanks a lot for your kind words.
Michael Brüning
Likes: 15 posts
Liked in: 163 posts
by 360-compunics-com-ni » Sat May 05, 2018 5:40 pm
I have released version 1.6 of the DeviceCheck plugin.
It now supports the PTP Splashscreen-feature, meaning that you can set a different graphic file for every device type (desktop/tablet/mobile). The remaining configuration settings as the overlay, time of auto-closure and so on are taken from the general configuration section, they stay the same for all device types.
The plugin does not support to deactivate the Splashscreen on some device type while activate it on another type.
As usual, exisiting DeviceCheck-users will be notified via mail and get the update for free on request.
