lightbox-like popup with scroleable html content??
Julien0577
by Julien0577 » Mon Jun 16, 2014 10:38 am
I can't find a clear answer to my question, does somebody have it:
Is it possible to have links/hotspots on a vistual tour that opens a lightbox-like popup with scroleable html content??
For both computers and mobile devices??
I saw only image or only text is posible, but don't know for html content.
Thanks in advance for your answer.
Regards.
Julien.
Re: lightbox-like popup with scroleable html content??
by mediavets » Mon Jun 16, 2014 11:02 am
Julien0577 wrote:Hi,
Regards.
Julien.
Welcome to the forum...
Not with PTP 1.8.
Are you talking about PTP 1.8 - you posted in a topic for 1.8 - or are you talking about PTP 2.x?
PTP 2.x supports Web site viewer plugins which provide just want you seek.
Julien0577
by Julien0577 » Mon Jun 16, 2014 11:33 am
Oh, it seems a good news!
I don't know any PTP, never worked with it, but if any version permits scrolleable html contents popups, I'll become an happy user! :)
So it seems PTP 2.x permits it.
Can you give me any example link?
Thanks for your answer!
by mediavets » Mon Jun 16, 2014 11:52 am
Julien0577 wrote:Oh, it seems a good news!
See: http://www.autopano.net/wiki-en/action/ ... EBSITE_BOX
You can download the PTP 2.x software and use it in trial mode to experiment for yourself:
http://www.kolor.com/download#panotour
by Destiny » Mon Jun 16, 2014 11:57 am
Hi..
You can add Light Box and a few other Box types but they are not as easy as adding a Kolor WebSite Box..
You can set the html contents to scroll, its not the box that does it....
Here are a multitude of options here.. Easy to do in PTP V2+
http://www.destinyvirtualtours.com/PTPV ... media.html
Julien0577
by Julien0577 » Mon Jun 16, 2014 1:25 pm
Thanks Destiny, with your last link I can see that all is possible and runs fine on mobile devices :)
Unless the object VR, why? (doesn't load on an android device, ok for iPad).
(offtopic: which software to use to make objectVR viewer? PTP too?)
by Destiny » Mon Jun 16, 2014 9:26 pm
GardenGnome for this one... And their support is excellent...
It works on my Samsung Note fine...
Julien0577
by Julien0577 » Mon Jun 16, 2014 10:13 pm
Ok, maybe a problem in my browser config, I'll check it.
Thanks for the link to object VR!
