little planet effect and iphone devices
argiro.starida
by argiro.starida » Sat Sep 29, 2012 6:40 pm
Hello!
I have used the little planet effect. It looks great on internet but it looks weird on iphone/ipad devices. I know it is not possible to see it on these devices because it's a flash thing but does anyone know if and HOW can I make it not play the little planet effect when seen by iphone/ipad? When it detects iphone/ipad devices to start the panorama without the effect.
thanx in advance
Argiro
Sam Rohn
by Sam Rohn » Sun Sep 30, 2012 10:49 am
yes, using the planet intro results in starting the tour looking at the floor on html5 devices as planets do not work on non-flash, disabling planet intro for html5 should prob be default behavior
to fix it, you need to set different starting view per device type via the krpano device attribute
http://krpano.com/docu/xml/#devices-notes
this is from a krpano project, but similar code should work for ptp
<!-- HTML 5 intro - no planet -->
<view
devices="html5"
hlookat="0"
vlookat="0"
maxpixelzoom="1.0"
fovmax="110"
<!-- little planet intro - flash only -->
<view
devices="flash"
stereographic="true"
fisheye="1.0"
fov="155"
fovtype="VFOV"
fovmax="150"
hlookat="0"
vlookat="90"
<!-- ETC -->
just add the device attribute as show to the appropriate xml elements as needed
sam
Sam Rohn :: 360° Panoramic Photography :: www.samrohn.com :: Location Scout :: www.nylocations.com :: New York City
PanoPress :: WordPress Plugin for 360° Panoramas in Flash & HTML5 :: www.panopress.org
argiro.starida
by argiro.starida » Mon Oct 01, 2012 3:01 pm
Thank you very much for you reply and the code!!!:)
I'll try it and let you know what happened.
Argiro
argiro.starida
by argiro.starida » Tue Oct 02, 2012 9:05 am
Hello Sam,
I've tried the code but unfortunately nothing happened. I'm quite new to all these. Do I have to put the code somewhere specifically in the xml? Or do I have to replace some of the code with the new one?
Thank you again for your help
Argiro
Sam Rohn
by Sam Rohn » Wed Oct 03, 2012 5:52 am
sorry, this was not meant as a cut and paste solution, you would probably need to be a bit familiar w modifying krpano code to figure out exactly what needs to be changed, panotour little planet intro code is laid out bit differently then the way i have been doing things in single pano krpano projects...
but the device tag and alt starting view for html5 is the way to fix it, perhaps someone more familiar w modifying ptp than myself could come up with a working fix, disabling planet intro on html5 should be built into ptp templates so maybe if you report this as a bug they can get it fixed in next release
sam
argiro.starida
by argiro.starida » Wed Oct 03, 2012 8:08 am
yes the copy paste didn't work but I tried several things and finally I made it work. Thank you very much for your help and the great starting point to the solution :)
Argiro
ATXcloud
by ATXcloud » Wed Oct 03, 2012 5:48 pm
Argiro, mInd sharing what you did to solve it? Thank you
Howdy from Deep in the Heart of Texas!
