[Panotour 1.5 b2]Only one HTML template enabling JS use or not...
by mediavets » Mon Oct 25, 2010 11:08 pm
I'm trying to understand what this means and why this change was made:
"Only one HTML template enabling JS use or not, and offering compatibility with mobile viewer"
I see no user configurable option regarding enabling use or not of Javascript.
renan
by renan » Tue Oct 26, 2010 8:00 am
The template use javascript if the navigator enables to use it and use simple HTML code if javascript is not possible.
