make the icon smaller in the map
asafmordechai
by asafmordechai » Sun Oct 24, 2010 7:13 am
hello.
is there a way that the icon in the map will be smaller ?
the to big for the map.
by mediavets » Sun Oct 24, 2010 8:48 am
Yes, in Panotour Pro.
See screenshot.
asafmordechai
by asafmordechai » Sun Oct 31, 2010 2:38 pm
another question, is there a way to make the hot spot smaller in the main view tour ?
by mediavets » Sun Oct 31, 2010 2:52 pm
asafmordechai wrote:another question, is there a way to make the hot spot smaller in the main view tour ?
Interestingly the ability to specify the size - offered with map hotspots - is not offered for pano point hotspots. I have commented on that previously.
So if you want a smaller hotspots on a pano, for now atleast, you'll just have to make your own and then select them via Display/Object/'other'.
