Video hotspot loop
urke
Video hotspot loop
by urke » Sun Oct 10, 2010 10:13 pm
I am making a virtual tour with several video hotspots, using flv objects. How can I make the video play only once (not loop)?
by mediavets » Sun Oct 10, 2010 11:03 pm
urke wrote:I am making a virtual tour with several video hotspots, using flv objects. How can I make the video play only once (not loop)?
You'll need to edit the XML files generated by Panotour Pro.
Here's a link to the krpano videoplayer documentation:
http://krpano.com/forum/wbb/index.php?page=Thread&threadID=812
It states that the loop parameter defaults to "false" but that appears to be incorrect, video invoked from within VTs created with Panotour behaves as if the loop paramater defaults to "true".
So you 'll need to add a loop="false" parameter in the XML where the videoplayer is called.
Here's one I made earlier, as they say on TV cookery shows:
<krpano version="1.0.8">
    <!--************** Panorama *******************************************************************-->
    <!--@File="video- hs-test-010.xml" @PanoName="[10]-DSCN4180_DSCN41830000" @FilePath="C:/Documents and Settings/Administrator/My Documents/[10]-DSCN4180_DSCN41830000.jpg"-->
    <panoview h="0" v="0" fov="90"/>
    <!-- view parameters -->
    <view fisheye="0" limitview="lookat" vlookatmin="-90" vlookatmax="90" maxpixelzoom="1.0" fovmax="90" fov="90" hlookat="0" vlookat="0"/>
    <!-- preview image -->
    <preview url="video- hs-test-01data/video- hs-test-010/preview.jpg" type="CUBESTRIP" striporder="FRBLUD" details="16"/>
    <!-- the pano itself -->
    <image type="CUBE" multires="true" tilesize="828" baseindex="0">
        <level tiledimagewidth="1656" tiledimageheight="1656">
            <left url="video- hs-test-01data/video- hs-test-010/3/1/%v_%u.jpg"/>
            <front url="video- hs-test-01data/video- hs-test-010/0/1/%v_%u.jpg"/>
            <right url="video- hs-test-01data/video- hs-test-010/1/1/%v_%u.jpg"/>
            <back url="video- hs-test-01data/video- hs-test-010/2/1/%v_%u.jpg"/>
            <up url="video- hs-test-01data/video- hs-test-010/4/1/%v_%u.jpg"/>
            <down url="video- hs-test-01data/video- hs-test-010/5/1/%v_%u.jpg"/>
        </level>
        <level tiledimagewidth="828" tiledimageheight="828">
            <left url="video- hs-test-01data/video- hs-test-010/3/0/%v_%u.jpg"/>
            <front url="video- hs-test-01data/video- hs-test-010/0/0/%v_%u.jpg"/>
            <right url="video- hs-test-01data/video- hs-test-010/1/0/%v_%u.jpg"/>
            <back url="video- hs-test-01data/video- hs-test-010/2/0/%v_%u.jpg"/>
            <up url="video- hs-test-01data/video- hs-test-010/4/0/%v_%u.jpg"/>
            <down url="video- hs-test-01data/video- hs-test-010/5/0/%v_%u.jpg"/>
        </level>
    </image>
    <!--************** Hotspots and lensflares ***************************************************-->
    <hotspot name="spot0" onclick="action(closeglobalobjects);action(closeallobjects);set(plugin[spot0object].visible,true);tween(plugin[spot0object].alpha, 1);plugin[spot0object].play()" url="video- hs-test-01data/graphics/spots/spot0.png" ath="322.123" atv="1.34328"/>
    <plugin name="spot0object" visible="false" url="video- hs-test-01data/graphics/videoplayer.swf" videourl="video- hs-test-01data/graphics/spots/object0.m4v" loop="false" pausedonstart="true" align="center" alpha="0" onclick="action(closeglobalobjects);tween(alpha, 0);delayedcall(0.5,set(visible,false));stop();" width="400" height="300"/>
    <hotspot name="spot1" handcursor="false" url="video- hs-test-01data/graphics/videoplayer.swf" videourl="video- hs-test-01data/graphics/spots/spot1.flv" loop="false" onclick="action(closeglobalobjects);togglepause()" distorted="true" ath="20.7369" atv="17.9641" width="240" height="257" rx="8.56886" ry="-10.3617" rz="3.63307"/>
    <!-- close all hotspots -->
    <action name="closeallobjects">set(plugin[spot0object].alpha, 0);set(plugin[spot0object].visible,false);plugin[spot0object].stop()</action>
</krpano>
urke
by urke » Thu Oct 21, 2010 11:12 am
@mediavets
Very helpful, thank you!
