customizing the themes.
pu2wxp
by pu2wxp » Thu Oct 07, 2010 9:39 pm
I'm not very good designer, very cool new themes Panotour PRO, but I need HELP in Portuguese, for example, and I wonder if I can get the source file to change this.
Luciano Correa
Vista Panoramica
Campos do Jordao SP Brasil
vincen
Kolor Certified Trainer
Likes: 23 posts
Liked in: 4 posts
by vincen » Fri Oct 08, 2010 6:14 pm
If you own Panotour Pro you can already create your own theme or duplicate existing ones to modify/translate them at your wish ;)
In Edition menu, you'll find a choice to open folder of themes and then you can play with them :)
Vincèn
Blog: http://www.skivr.com
pu2wxp
by pu2wxp » Fri Oct 08, 2010 7:40 pm
vincen wrote:If you own Panotour Pro you can already create your own theme or duplicate existing ones to modify/translate them at your wish ;)
Vincèn
Really? Where do you think I took this picture?
You just told me the obvious. I looked in XML and there's nowhere to translate this HELP I posted above. Edit the file help.png I don't know if it is a good idea because it could ruin the theme.
I would just like to translate into Portuguese!
If someone send me the source file I translate and send back, so that all who speak Portuguese may have to use this too.
Luciano Correa
Vista Panoramica
f7
by f7 » Fri Oct 08, 2010 8:39 pm
En espaà±ol:):)
