[Panotour 1.5 B1] Order of pano list and thumbnails?
by mediavets » Sun Sep 26, 2010 10:39 am
I know how to set the pano to be displayed first in a tour, but...
1. What determines the order of the remaining panos in a drop down list?
2. What determines the order of the thumbnails?
3. Can I somehow force/determine the order of the panos (other than the fist) in the frop down list?
4. Can I somehow force/determine the order of the thumbnails?
digipano
by digipano » Mon Sep 27, 2010 3:35 pm
Numbering them should work ie: 01/ 02/ 03
by mediavets » Mon Sep 27, 2010 3:55 pm
digipano wrote:Numbering them should work ie: 01/ 02/ 03
Hmmmm...a very clumsy 'solution' though wouldn't you say?
Doesn't make for user-friendly title on the drop down list nor for user-friendly tooltips on the thumbnails.
digipano
by digipano » Mon Sep 27, 2010 4:19 pm
Clumsy YES, but as of now that what I found as a solution. I don't know how else would we have any other method within the GUI.
JohnM
by JohnM » Mon Sep 27, 2010 6:34 pm
The obvious answer is to is to do ordering in the xml file.
by mediavets » Mon Sep 27, 2010 7:50 pm
JohnM wrote:The obvious answer is to is to do ordering in the xml file.
Errrr....yes, but we're talking about wanting to be able to set the order via the GUI.
renan
by renan » Tue Sep 28, 2010 12:19 pm
I add this demand in the wish list, I don't know yet if it will in the next beta or later...
