Editor plugin
JohnM
Editor plugin
by JohnM » Sat Sep 25, 2010 3:47 pm
How may i include the editor plugin in exported Panotour Pro files ? ( except for doing it manually )
renan
by renan » Tue Sep 28, 2010 12:32 pm
Open the template directory via "edit" menu.
Duplicate one template. Insert the krpano code for including the editor plugin (the editor plugin must be at the location indicated in this code).
Added code and editor plugin will be used when this template menu will be selected.
The new template menu must also be added in "themes" templates to be accessible into Panotour.
JohnM
by JohnM » Tue Sep 28, 2010 6:28 pm
Will Panotour copy the swf to output folder, or do you say that I must do it manually ?
renan
by renan » Wed Sep 29, 2010 7:59 am
All plugin objects of template file will be automatically copied in the output folder. The initial object must be at the location indicated in the template (ie if url=editor.swf, the editor must be in the template directory)
