[Panotour Pro] custom templates
by gkaefer » Sat Sep 25, 2010 2:54 pm
How can I use my custom created templates from APT. There is no single subdirectory under PTP installation path where I can find the listed default custom templates, so I assume the "custom templates" created by APT/PTP user cant be implemented/used with PTP?
Liebe Gruesse,
by gkaefer » Sat Sep 25, 2010 2:59 pm
gkaefer wrote:How can I use my custom created templates from APT. There is no single subdirectory under PTP installation path where I can find the listed default custom templates, so I assume the "custom templates" created by APT/PTP user cant be implemented/used with PTP?
Liebe Gruesse,
omg...
the template directory moved from install dir to windows default:
C:\Users\XXX\AppData\Local\Kolor\PanotourPro15\Templates
Cant this be changed by user?
by mediavets » Sat Sep 25, 2010 3:21 pm
Liebe Gruesse,
omg...
Comparing APT V1.1 berta 9 an PTP 1.5 beta 1 it seems to me that the tamplates folder if in the same logical location in the file system?
But I think any custom navigation template will no longer work alongside Panotours new themes feature?
