Stitching disarray
zeller
Stitching disarray
by zeller » Tue Sep 11, 2018 4:39 pm
I have made the jump from hardware stitching in a Ricoh Theta to software stitching in Autopano Giga using images from a GoPro Omni. Most of my images stitch properly. All I need to do is adjust the center, straighten, etc. But a few rendered 360s show notable problems in the stitching. If you look at the attached file of a small chapel, you will see that the top of the confessional partition (to the right of the center point) is poorly stitched. The door is also not stitched properly.
I have tried introducing manual control points, but when I do so the render is no better, and the software reports poorer stitching quality than it had before (going from a green to yellow flag). I attach a screen snapshot of my attempts to add manual points (#67-70) to correct the problem with the stitching of the confessional partition.
Does anyone have any advice?
Screen snapshot
Rendered 360
olivierbo
Liked in: 134 posts
Re: Stitching disarray
by olivierbo » Thu Sep 13, 2018 8:14 am
You can't avoid parallax issues using that kind of RIG, especially on close objects. In your case, you also have homogeneous areas with a lack of details.
Have you tried to increase detection quality, add manual control points (pixel accuracy). Have you also tried to use Omni importer then export to Autopano ?
Kind regards,
Olivier
zeller
by zeller » Thu Sep 13, 2018 9:47 pm
Thanks, Olivier, for your response. I am using the Omni importer, yes. I did try manual control points, but they didn't help. I'll try to increase detection quality too. But at this point I wonder if my best option isn't to either reshoot with the dual-fisheye Ricoh, or try to fix it in Photoshop.
olivierbo wrote:Hello,
Kind regards,
Olivier
