Autopano Giga - Clauss/Rodeonpreview - Critical error
sales@burghmuir.com
by sales@burghmuir.com » Mon Jun 18, 2018 3:20 pm
I'm finding difficulty in resolving a critical error I keep experiencing whilst using the Clauss Rodeonpreview/Autopano Giga software.
After creating the pano within Rodeonpreview and exporting directly to Autopano Giga I keep experiencing a critical error
Critical Error - "Exception: Not enough memory in File ".\\KImage.cpp" Line 276" which happens at Rendering Preview
My setup is:
x64 - Win 10 - 16GB Ram Autopano Giga 4.4.1 Clauss Rodeonpreview 2.5.2
Any thoughts?
Graham
olivierbo
Liked in: 134 posts
Re: Autopano Giga - Clauss/Rodeonpreview - Critical error
by olivierbo » Tue Jun 19, 2018 2:54 pm
Do you have enough space on your HDD/temp folder? Also, any other software you could close?
Did you experienced that issue before?
Kind regards,
Olivier
sales@burghmuir.com
by sales@burghmuir.com » Wed Jun 20, 2018 10:03 am
Many thanks Olivier for reply.
Just to confirm the following;
HDD/temp folder space = 2.25TB free space
No other apps operating ex Rodeonpreview
This has been my first attempt of using Autopano Giga with Rodeonpreview.
Regards
Graham
olivierbo
Liked in: 134 posts
by olivierbo » Wed Jun 20, 2018 10:09 am
Hello Graham,
I can test on my system if you give me more details about the version of Rodeon preview software you are using (I saw different versions on their site) and any other information/configuration I will need.
Why do you need Rodeon preview exactly. Have you tried Clauss import wizard?
Kind regards,
Olivier
sales@burghmuir.com
by sales@burghmuir.com » Wed Jun 20, 2018 2:53 pm
Many thanks Olivier,
I've had tunnel vision, just tried using the Clauss Papywizard wizzard and that works perfectly with AP Giga.
Thanks again for your help
Graham
