Help Detection by specifying rows & columns   [SOLVED] - View the solution
dzeek
Likes: 3 posts
by dzeek » Thu May 10, 2018 2:30 pm
APG has great difficulty detecting the proper arrangement of images for a pano with a large number of images. Is there a way to tell it on import of the images the number of rows and columns and the order (for example, zig-zag, left-to-right)? I would think this would make the process a lot easier and automated. I'm using for panos shot with a DSLR on a pano head and it's a real pain having to correct things manually.
Panoram1x
Liked in: 41 posts
Re: Help Detection by specifying rows & columns  [SOLVED]
by Panoram1x » Thu May 10, 2018 2:44 pm
Experimentation is the funniest way to learn, to ask the fastest
jordi.panoram1x[at]gmail[dot]com
dzeek likes this post.
dzeek
Likes: 3 posts
by dzeek » Thu May 10, 2018 3:06 pm
Thanks. I will try it.
dzeek
Likes: 3 posts
by dzeek » Fri May 11, 2018 2:26 pm
That works. Thank you very much!
